Alright guys.
Had my cupra a few weeks now and although it my first turbo car the power seems to be a little hit and miss.
Maybe I'm expecting more from the car. I was told it was standerd but its has a forge split r dump vavle. And a green air filter. And a boost gauge.
Reading on here a standerd cupra should boost to between 5-8 psi. On the gauge mine was hitting 15 and then droping back to above 10 though the gear.
But the car feels starts to pull then pull a bit harder then runs out off puff. And feels like it it struggles to get above 80 although it will pull above this just takes a while and in 4th and 5th it seems to hold close to 15 psi and dropping slowy.
I have got a eBay fault reader and I had 3 codes come up.
second air injection system
A 02 lamba sensor
Negative pressure (boost leak)
Since then I have been round and tightend any clips I can. And also did the n249 bypass. And cleared the codes. Now it says I have none. But today I though I'd try unplugging the maf and see how the car drove.
With it unplugged the car idles fine and drives nearly exactly the same to drive with a very slight improvement.
The boost gague is now reading close to 20 psi before dropping.
So do you guys think the cars been mapped and running ruff. Or do we think it could be standard and the boost gauge is broke/breaking
Leigh
A 02 lamba sensor
Leigh
