Little problem with recoding my key....
slick
Bit of an animal
Mar 15, 2005
1,124
Essex
I was looking at buying a VW flip key and cutting the blade etc and recoding it, so i started to read up on it, now i found a problem in the plan...
To recode the new key you need to lock the car and have another key in the ignition... my problem is..
I DELOCKED THE DRIVERS SIDE....:cry:
Now is it possible to still recode it or is it simply impossible now the car is delocked?
:shrug:
Any help people
lc_allan
Northern Monkey
Sep 15, 2006
3,389
Is it not worth putting the old lock barrel back in just to recode?. I know the metal disc might be tricky to remove but it has been done.
slick
Bit of an animal
Mar 15, 2005
1,124
Essex
Yeah well i was thinking that, but that metal disc is going to be a absolute bugger to remove...its meant to be that way... DOH!
Have to have a go i guess...do you know who did it, see if i can get a pointer on how he/she did it, save me losing all feeling to my fingers in this weather...
lc_allan
Northern Monkey
Sep 15, 2006
3,389
I thought Pabs mentioned once he'd reversed it but I'm sure someone will be along shortly who has :)
slick
Bit of an animal
Mar 15, 2005
1,124
Essex
you thought about trying to code it using the lock button on the inside of the door, could be a long shot but might work
Hmmm.... good idea, need a SEAT tech to verify that fact.... any SEAT TECHS around....???
Otherwise Pabs is going to get a PM very soon!:lol:
lc_allan
Northern Monkey
Sep 15, 2006
3,389
The manual is specific about recoding the key. I doubt it would work from the inside.
You also got the transponder out of a spare key or a new on with the VW key?
slick
Bit of an animal
Mar 15, 2005
1,124
Essex
I guess i can only try! thanks guys...buy the key next month i think, the transpoder i will take from the non remote spare key i have!
lc_allan
Northern Monkey
Sep 15, 2006
3,389
Becareful removing it :redface: . Mine was bonded/glued in and although intact and very carefully removed I think I may have damaged it and it wasn't coded on the first try. However I managed to buy two new transponders off someone on here. I didn't try the second time and just used a new one.
2002tii
can you not go to the dealers to have it plugged in to a diagnistic?. to recode
SWANSWAY CUPRA Dealership
