location of outside temp sensor
farrar
567
17
Can anyone tell me where under the bonnet the outside air temp sensor is located. I have had a problem before in that the compartment that its located in fills with water and the temp reads wrong. Usually very high like 58c. It's a pain when it happens as it messes up the climate control so i only get cold air.
Thought if i could find it i could save myself a trip to the dealer if i drain it myself.
farrar
567
17
Thanks, my car is different from the Leon in the photo. Mine has no wire in the middle, only on the top and its just a cylinder shaped piece of plastic with a compartment on the front. Hopefully I'll be able to unclip the compartment with a screwdriver and blast out the water with some compressed air.
