Long Locking Wheel Nuts
Jonzy
Maybe one for the Badger this...
What length locking wheel nuts are needed for cupras running spacers? Im assuming the tapered seat is 60*? I belive the standard lockers are 26.4mm, so somthing like a 42mm would be sufficent?
Cheers :)
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
presuming 15mm spacers, 45mm thread is typical size. (and I believe the longest locker you cabn get-or is for me anyhows)
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
spacers with std bolts are £79.10 for 4x100 fitment..
lockers, come in sets of 4.
2 ranges... £19.99 for cheaper options and £35 for thatcham listed jobbies
regards
bill
Funkyfin2000
Black Leon Cupra R 280bhp
Oct 6, 2005
2,477
Stafford, Staffordshire
im getting very confused.....
presumably for the 15mm spacers no the rear i need a set of
12mm x 1.50 (Locking Bolts)
and then what nut do i need for the end?
Is it?
12mm x 1.50 (Closed End Locking Nut) -
12mm x 1.50 (Open End Locking Nut)
Whats the difference?
I don't know what to get! please help! :)
Molehill_Mike
Rollin' on 20s
Jan 3, 2005
2,566
Bedfordshire
Yeah I am thinking of going halfs with someone as I only need 2 for the rears...as do they
So if we can get a set with 2 locking wheel nut KEYS then thats sorted ;)
Mike
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
open nuts have thru holes (you use studs into hubs) and closed nut are not thru hole,,,, so thethe studs need to be sized right to not bottom out.
Or
Get longer locking bolts
Molehill_Mike
Rollin' on 20s
Jan 3, 2005
2,566
Bedfordshire
Need to see if we can grab a set with 2 KEYS first fella, &FlashBsd kiinda called it already, but if Badger can supply I am sure LOADS of MK3 Cupra peeps will be after going halves on a set...
Mike
