Here's mine when I first fitted it:
It's a terrible picture.
That's the programmed channel list on the radio that appears in colour.
That's the one.
Yeah you can turn the brightness right down depending on your preferences
From memory it was the first picture I took of it before I started tinkering with the settings so it was on full volume, beep when you touch the screen, super bright, no channels stored etc etc
It has a full touch screen, beeps when you press it but it was turned off very quickly.
The veyron unit has maps for uk and Ireland installed and is supplied with a GPS antenna.
Not bad, is good value for money then. I'm not personally after the OEM look as I want a more simplistic look but deffo worth it if thats what you're after.
