RainyDay
92
7
Hi guys. Does anyone know if there are camber plates / rear ARB for sale anywhere for the Seat Ibiza FR 1.5 (2017+)
Also, my rear toe alignment is off, I was wondering if there is any way to solve the problem considering the rear suspension isn't independent?
Thank you
I don't think rear ARB is not available for our cars, due to the U shaped "semi-independent" rear suspension.
In my opinion this is the only big unsolvable drawback for this car.
Also, the car really does not like being driven hard downhill, due to the weight transfer.
The rear is quite light and stiff, resulting in overseer in such conditions :'(
I've tracked it and didn't find it too oversteery to be honest. It was fairly neutral and tending to understeer a bit which is why I wanted the ARB. It's unfortunate there's no arb for it. Maybe I'll have one custom made, do you think that would work?
Also since I posted this I got coilovers and have a bit more toe and camber on the front as a result which has helped quite a bit. The only remaining annoyance is the very intrusive stability control that can't be turned of fully and causes wierd handling at the limit
