phil22
hi all me again when i bought my ibiza about 2 months ago it was already lowered 60mm but it seems to understeer alot so at the mo if it does i can ease off the throttle and out comes the arse end full on drifts but a buddy told me this is because the chamber has change is this right and if so how do i adjust it or who can adjust it thanks would perfer to do it myself though
phil
did you not get it aligned after you lowered it?
you need to take it to a professional to do this.
as i said it was already lowered when i bought it how much will it cost then for me to get it aligned then? thanks for your quick reply
phil
deffo go get it checked for alignment, when I lowered mine it kicked everything out of kilter, and was way out of track.. now it grips like a fly on velcro
:D
where i get my 4 wheel algnment done is about circa £30 IIRC
i was quoted by a tyre/exhaust/brake type garage; "£50 to set up the equiment , but for every adjustment to the car, it was £10 per item ":confused: (i can name and shame if required:whistle:)
ie:- 4 wheel alignment = one item,
front toe = one item,
rear toe = one item,
front camber = one item,
rear camber = one item,
because of labour involved:ban
Total £100 :blink:.......
i walked out.......
in short, ring round everywhere for quotes as you can pay alot less / more for the same thing! ;)
If you can stretch to it go to an independent VAG specialist who can offer a Beissbarth 4 wheel alignment. In the hands of a well qualified professional the car will transform. And don't be fooled into thinking a $hit Fit alignment will be sufficient either!
Agreed, that's the secret here - you need to find somewhere that doesn't just have the gear but the know how to use it. That's worth paying a few quid for.
out of interest, what makes this different? :shrug:
Beissbarth are now owned by Bosch, and they are reputed to make the worlds most innovative wheel / tyre tools. They're kit has some amazing technological advancements on it (including the first non contact wheel alignment system).
Think how badly the average wheel is balanced these days using eons old crappy old machines. If you are going to make the effort to spend big money on decent suspension you owe it to yourself NOT to cut your nose off to spite your face at fall at the last hurdle. Do it right!!!
iirc it's about £100 for it to be done on a beissbarth system. But it is very technically advanced.
Another thing to remember is that most places can't do the wheel alignment on low cars as their equipment either does not fit under the arch or they cant get under the car to adjust it. Needs to be a system which fits onto the wheel like the beissbarth one.
done mine with a tape measure a broom handle and a keen eye, that was over 18 months ago now, but maybe im just that damn good lol ;)
