the maf is 2.5 inches bore size and on the diesel cupra it is 3 inches probably a good mod for a 20vt on ko3s turbo but pricey as you need to buy the complet airbox an the maf housing cant remember how much i payed for this
you dont want to change the maf size, unless you are going bigger turbo and will have a custom remap to take account of the changes.
If you put a larger diameter maf on and dont get the ecu adjusted to take this into account, then the reading the maf is providing (how much air is entering the engine) will be incorrect.
Ok but then the question remains of the size of the original MAF, I want to add a 90 degree bend for my airfilter and want to order, so is that also 2.5"?
