Oct 9, 2020
Hello all,
So I replaced the dipped with OSRAM Night Breaker Lasers, is it best to fit the same for the main beam as the cheap ones from ebay make no difference.
Or are there other recommendations for the main beam.
Thanks in advance
I've always only fitted genuine Phillips Extremes, though Osram Night Breaker should be equivalents, so yes stick with proper brands is my way of doing things.
Would always recommend the branded bulbs. Philips Xtremevision 130s or any of the Osram Nightbreaker range should be fine. However if you want the max brighteness from a high beam bulb, go for the Philips Racing Vision. As you probably won't use high beams that often, the shorter lifespan shouldn't be an issue.
