Main shaft bearing
slimwiltaz
279
Hey guys. Had a rattle from my gearbox on idel, just had a full clutch and flywheel fitted today and noies is still there. Ive been told the main shaft bearing is a common problem on these? Whats the best way of getting this sorted?
Sent from my ST25i using Tapatalk 2
slimwiltaz
279
Sorry. Its a seat leon cupra 1.8t 180 on a 53 plate
slimwiltaz
279
Anyone know any good places that recondition gearboxes in the north east?
wildrides
396
If the noise goes when the clutch peddle is on the floor its the gearbox input shaft rear bearing normally but change all four .
slimwiltaz
279
Cheers for reply. Bit gutted really thought the clutch and flywheel would of sorted it
slimwiltaz
279
Interesting read but my gears are fine go in easy with no noies. Its just at idel theres a knocking noies that goes once clutch is pressed. Ive changed clutch/fw no luck :-(
wildrides
396
slimwiltataz ...................its the bearings on the input shaft allowing the shaft to wobble that make the noise .
Your gears will be fine if you get the bearings done ASAP . The noise dissapears when the clutch is on the floor because that is the only time the gearbox input shaft stops spinning . The reason you only hear it in neutral is that when in gear the vibration / knocking is absorbed by the engaged gears and goes up the output shaft to the diff and drive shaft . In other words ....... when in gear the input shaft has no room to slap about on its worn bearings ........ the gears hold it tight .
wildrides
396
North West Transmissions ........... liverpool are good . They will courier your box on a pallet from your house ....... fix it and deliver back .
They did my wifes toyota 5 speed for £400 all in ( just the failed bearings ) full rebuild with every wearing part renewed ( syncro etc ) is about £750 both prices include collect/delivery
I dont know if they will collect from north east tho
slimwiltaz
279
Thanks man great info. Think ill do a bit ringing about get sum prices on replaceing bearings. Ill park it up and use the wifes ford ka haha
