It does drop of about 5krpm to about 1.1 bar, it was supposed to hold 1.3/1.4 bar according to the revo dealer, I had an issue with my n75 bouncing and all sorts so new it was on its way out so replaces it with the unos
As said the k03s turbo will start to run out of puff at 5k rpm and boost will hold around .9-1.1 bar , if it's set at 1.3 bar you won't make more power top end
Yea like u said but it peeks and holds rather than peak and drop off straight away it now holds much more boost round the rev range with this fitted now
Just to remind everyone the ball and springs in MBCs need a clean every so often as they can get clogged up, also the settings change due to various factors. so keep an eye on your boost :)
the benefit is you can bypass the n75 valve and raise the boost but on a standard car not adviseable cause just raising the boost while make your car run lean (nut enough fuel) timing and fueling have to adjusted to suit the requested boost . car running lean will create very high cylinder pressures due excess heat the ecu will adjust abit to try and compensate but only to a point. i only would run a mbc to stop stupid spikes on a mapped car
Got you. I had N75 problems but since sorted. I liked the idea of keeping the car on boost longer through the rev range.
Does anyone have a picture of their MBC fitted inline with the N75? I think I know what I'm doing but just for sanity really (and it's nice to see how people chose to splice their hoses etc..)
