you need a ball and string type MBC
http://www.ebay.co.uk/itm/UNIVERSAL...arParts_SM&hash=item336abf5216#ht_1607wt_1037
many will say get forge unos but this is just as adequate
the benefit is you can bypass the n75 valve and raise the boost but on a standard car not adviseable cause just raising the boost while make your car run lean (nut enough fuel) timing and fueling have to adjusted to suit the requested boost . car running lean will create very high cylinder pressures due excess heat the ecu will adjust abit to try and compensate but only to a point. i only would run a mbc to stop stupid spikes on a mapped car
