Alright mate, looks like you covered all the bases there!, The crank sensor is located in a little recess behind the oil filter, its a pain to get at. You need to remove a bracket which holds on the front engine mount bolt, to do this you need to remove your starter. It makes life a lot easier if you remove the oil filter aswell, could do a oil change while your at it to make it worthwhile, I changed my sensor about 3 months ago on a 99 plate 16V and it was totally shot, corroded wires etc. I had an annoying misfire on an astra many moons ago and it turned out to be nothing more than an incorrect gap on one of the plugs. Hope you get it sorted mate.
