I did some logs and now I'm really confused.
Totally different results to logging on previous remap.
With the revised map, TSR is right, it is pretty much making requested boost top end but not bottom end. I thought the new map was requesting more than that though.
MAF figures look good peaking at 162g/s, although wastegate duty is looking quite high for the boost I'm getting isn't it?
I'm worried about the timing though as on the previous map I had hardly any movement on the figures but now I am.  I did a torque run just for fun and got 208 lb/ft at 4200rpm.
I don't think I have a boost leak else it wouldn't be reaching requested boost at any time (am I wrong?), but I'd expect it to make closer to requested boost lower down. Maybe my actuator is a bit duff or could it be the turbo?
I have a little fin damage on the Laguna intercooler where it had caught on the bumper. That's been fixed now and I understand the fins only
help to cool, the air runs through the horizontal lines which are fine. You will see I saw max 33 deg which was on it's second run so that must be working and not leaking, and the air feeds to my open cone filter are doing their job.
Suppose there could still be a blockage somewhere though, like in the intercooler or cat, or it's the actuator?
Please let me know your thoughts. Many thanks.
P.S. Can anyone enlighten me what 'injection on time (ms)' is on block 002 and whether it looks OK?
BOOST, INTAKE TEMPS & WASTEGATE DUTY
		Code:
		Group B:	'115					Group C:	'118
	RPM	Load	Req Pres.	Act Pres.			RPM	Intake	Load	Absolute Pres.
TIME						TIME
STAMP	 /min	%	 mbar	 mbar		STAMP	 /min	°C	%	 mbar
0.29	1920	51.1	990	1040		0.6	1960	24	1.2	1050
0.99	2000	96.2	2250	1160		1.4	2120	24	95.3	1320
1.69	2160	118.8	2260	1440		1.99	2240	23	95.3	1560
2.39	2400	139.1	2250	1740		2.79	2520	23	72.5	1900
3.09	2640	155.6	2220	1980		3.39	2760	23	69.8	2020
3.69	2880	154.1	2210	2020		4.1	3000	23	71	2020
4.41	3120	160.9	2190	2030		4.7	3240	24	74.1	2040
5	3360	160.9	2170	2040		5.31	3480	24	74.9	2040
5.6	3600	159.4	2160	2030		5.9	3720	24	76.1	2010
6.2	3840	160.9	2160	2020		6.5	3960	24	76.9	2010
6.81	4080	160.9	2160	2010		7.21	4200	26	83.5	2030
7.51	4320	166.2	2150	2060		7.81	4440	27	85.1	2110
8.11	4560	171.4	2110	2130		8.41	4680	27	92.5	2110
8.82	4800	169.2	2000	2070		9.22	4960	29	90.2	2000
9.52	5040	163.9	1940	1960		9.82	5160	29	90.2	1940
10.12	5240	157.1	1920	1910		10.42	5320	30	91.4	1900
10.72	5400	153.4	1910	1910		11.02	5480	30	91.8	1900
11.32	5560	148.9	1890	1870		11.62	5640	31	92.5	1860
11.92	5720	145.9	1880	1830		12.22	5760	31	94.1	1810
12.52	5840	142.9	1860	1800		12.82	5920	32	95.3	1780
13.22	6000	138.3	1810	1770		13.62	6080	32	94.9	1730
13.92	6160	135.3	1790	1730		14.22	6240	33	94.1	1730
14.52	6280	132.3	1770	1720		14.82	6320	33	93.3	1700
15.12	6400	130.1	1750	1700		15.43	6440	33	92.2	1720
15.73	6560	123.3	990	1800		16.03	5920	32	0	1400
TIMING PULL, MAF & Injection Time
		Code:
		Group B:	'020					Group C:	'002
							RPM	Load	Inj.Time	MAF
TIME						TIME
STAMP	 CF	 CF	 CF	 CF		STAMP	 /min	%	 ms	 g/s
0.71	0	0	0	0		0.4	2040	27.1	3.28	12.56
1.3	0	0	2.3	0		1	2120	76.7	10.66	38.67
1.9	0	0	0.8	0		1.6	2240	105.3	13.12	50.47
2.5	0	0	0	0		2.2	2440	125.6	15.58	63.28
3.2	0	0	0	0		2.8	2640	143.6	18.04	74.92
3.9	0	3	0	0		3.6	3000	148.1	18.45	85.17
4.61	0	3	3	3		4.21	3280	153.4	19.27	94.97
5.32	3	3	3	3		4.91	3560	155.6	20.09	102.64
5.91	3	3	3	3		5.62	3880	159.4	21.32	116.67
6.61	3	2.3	3	3		6.22	4080	158.6	21.32	123.92
7.22	6	5.3	6	5.3		6.92	4360	164.7	22.55	140.42
7.92	6	5.3	8.3	5.3		7.52	4600	171.4	23.78	150.17
8.62	6	5.3	8.3	5.3		8.32	4880	167.7	24.19	154.58
9.32	6	5.3	8.3	5.3		8.92	5040	162.4	23.78	155.33
10.03	6	5.3	8.3	5.3		9.72	5280	157.9	23.78	157.25
10.63	6	4.5	8.3	5.3		10.33	5400	154.1	23.78	158.36
11.23	5.3	4.5	7.5	4.5		10.93	5560	150.4	23.78	158.97
11.82	5.3	4.5	7.5	4.5		11.53	5680	146.6	22.96	160.11
12.43	5.3	4.5	7.5	4.5		12.12	5840	143.6	22.96	161.28
13.13	5.3	4.5	7.5	4.5		12.83	6000	139.1	22.14	159.72
13.73	5.3	4.5	7.5	4.5		13.43	6120	136.8	21.73	160
14.43	5.3	3.8	7.5	4.5		14.13	6280	133.1	21.32	158.94
15.03	4.5	3.8	7.5	3.8		14.73	6360	131.6	20.91	159.67
15.73	4.5	3.8	6.8	3.8		15.33	6480	128.6	20.5	159.44
