mk1 golf caddy/homemade 24v v6 4wd turbo
suj
Wheel Connoisseur
Jan 1, 2009
5,808
Birmingham
been reading this for ages, and love every min mate
i would love to come help out/learn off ya mate! it's a beast and i wish you would start a business, as you know your stuff and could make a killing in the car scene mate!
hopefully its running/boosting again soon! :D
powernut
475
top replies guys ,,;)soona s daylight hits ill thow the rest of the wiring in , bolts a few bits and bobs and have a go at fireing the bugger up fingers crossed all is well , ill pop a video up too :D
powernut
475
managed to do a bit more and a quick video , finaly got the engine runing too
not good qual..ty (mobile )
http://tinypic.com/r/1zdlt7d/4
should have it the other bits done 2moz ready for its road test monday
powernut
475
its only a scrap heep idea lol , all reclyed from scrap steel too:p leeds not too far around 40min drive
beeza_warrior
amazing the amount of skill you have, just read from the startmust of taken me 2 hours but what a read :)
Lodgey180
WoOoOoOsShH
May 3, 2008
1,046
Middlesbrough
www.mootr.co.uk
just gets better and better everyrtime i read it lol
you seem like a sound guy aswell. dont like these people who think there better because they got big power and get snotty when asking a genral question..
good luck with the rest of the build lol..
air121005
1,609
Worcestershire
looking really good now, sounds nice aswell!!
bet you can't wait to get it out on the road?
on a side note, towards the end of that vid as the camera pans up towards the air filter there seems to be a leak / puff of something comining from hose joiner / behind the engine / left of the turbo, might be worth checking your connections !;)
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
Drive it til you break it, then fix it/make it stronger :clap:
Can't wait to see the road trip :clap:
powernut
475
cheers guys , i just a normal guy really not stuck up ,just did this for somert differnert i supose ,,,
that smoke was the engine breather pal lol nothing seroius ,,
but ive dam proper over fueling issuise at mo ,
ive a problem which im sure is electrical , everything was fine until i refitted the new engine ,
problem is , when the igition is switched on i usely hear 1 click which usely comes from the injectors , but now when i turn the igition on it makes a constant click click click etc for approx 6 to times 8 b4 it stops , and its eating fuel like turning a tap on , and which it runing really rich ,so im 95percent its a injector wireing fault were im unsure as it also dose this when the engine is turned off , , ive cheked all the earths and the main live feed which is coupled to the coil pack then run back inside the car , ive also re checked the ecu and re burnt my map , (it wouldnt sent first said low voltage ) then it resent , still having the same problem , as i thought it was a air problem with dragging air in on the manifold , but its defo fuel as 1 galon lasted 4mints , lol , it as also blown the injector fuse ???
ive changed the fuel reg
all 6 injectors
checked all earths
