ill make u smile when some footage is up,#
this is what happerns when u attempt high speeds lol
as this is a problem this is what happerns when u have full front brakeing force over 160mph (dont laugh)both front calipars snapped ,ochh
...im unsure i defo know it will do more due to calicating the ratios which come out at 254mph 7500 in 6th lol
lol cheers , but if u think about it , these were stock mk4 golf calipars ,now sorted and only a minor set back , (i could understand if my weld had broke , lo but for a un modifyd calipar i have to blame vw lmao/pmsl(they should make em strongeryou just need to find that long road in a vacuum and you will be spot on...
The Moons, M25 orbital ring road should suffice, safely away from other road uses to boot. breaking calipers?you really scare me... you really do
lol cheers , but if u think about it , these were stock mk4 golf calipars ,now sorted and only a minor set back , (i could understand if my weld had broke , lo but for a un modifyd calipar i have to blame vw lmao/pmsl(they should make em stronger![]()
breaking very heavily from 170+mph that would exert massive forces to which it wasn't designed for. how heavy were you on the brakes / what speeds were you at when that failure happened?
moderate breaking would only subjected the carrier to similar forces regardless of what hub its fitted to?
a MK.4 golf is heavier than a MK.2 Caddy, so i'd of thought that failure could well of happened on the original car![]()
cheers , ps i think were havin a bit of confusion regards brakes and ive also found the faults which sure i meations , the brakes were fine, problem was the amount of braking force was on on the front and buggar all on the rears , as i fitted rear conpansators , which was a problem , but this is the joys of modifying a vechical , so now im fitting some twin pot wilwoods ,on the front so lets see how these perform of to pick these up tomozGood work as always fella
Think those brakes, breaking at over 160 would have been very scary![]()
heard that b4 lol bigger brakes im runing 334mm dustin lids now lolYou need locking up mate!
And much bigger brakes lol
keep the updates coming![]()
Truly work of god. Really impressive mate. Congrats on the build and hope you reach your goals.. If your stuck for brakes, drop me a pm.
