Lol i think its boss the way you just take it apart an wack it back together again lol
It's something that would cost proper brewsties at a garage to get done. Im getting myself a whole new set of tools for my birthday to make some progress on the Polo. Might give you a shout on advice on what would be best to make me exhaust with if thats ok
the engines runing verywell no silly probs , but im not risking lifting the boost on these 83.1 pistons , but i wont more boost , (gets boring after a while lolol)
so ive been keeping a keen eye on upgrades and didnt take long at all look at these babys i dropped on utter bargin there are..
s.p stage 2 high beam con rods with bigger arp 2000/7/16 bolts :D price 120 ,,,couldnt say no,,,
next bargin wasnt far away complete set of wossnerr pistons 200 ,off ebay :D
pics here
well they have arrived look ok ,soon see what happerns after a spot of run in ,,
so i think its time for some serious boost what u guys think,,,,:thumbs_up
i try i need soe driveshaft snapping power so i can keep beefing stuff , mind ive only just built my currant vr6t runing 25psi on my own custom 83.1mm pistons , but its not worth knackering a good lump up ,, so ill get this other built up should hold good boost ,,,unsure how well but ill find out lol
cheers guys be a few more useal engine rebuild pics poping up this week , bloody vr6 , lol no need to look at how they come apart , do it blind folded now pmsl
i was thinking only the other day...."what has happened to that caddy??"
awesome mate!
some good prices on those parts! .....as you say "couldn't say no"!!!;)
edit: just had a look on the Wossner website......:wtf:they are £500 EACH!!!!.... and you got 6 for £200!!! :clap:
yearh im unsure if these are copyies or oringal wossnerr pistons , they feel light , have some markings rubbed off inside and oil rings look flimsy , pistons coatings have slight over spray, maybe me, but unsure,
/ still there getting banged in pmsl
if they are im glad i didnt pay full wack for these things (bet i could make a seton lathe pmsl), as i pref my own i fitted here...........................
next block came back rebored out for 83.1mm pistons ,
so poped pistons in (not bad for a guess approx 2mm from the top bore lip with deep centres,
im stillsure i can run 30psi lol but i not risking it on this engine ,
engine torque settings here ,incase anyone needs them
i wouldnt personly sell this block as engines not evern un in , yet reoveing to try these others , i must be mad lol
You are a very smart man :)
nar i wouldnt go that that far , more like has a go , as im fed up , stripped engine ready for pistons and rods ,then found the rods wont fit down the bores:(dam things, )this is because these are stage2 rods meaning,
vr6 12v are stage1 81mm bore
r32 24v are stage2 84mm bore
its too risky rehoneing a 12vr6 because the block walls will be thin/may crack with boost
and carnt have 4mm removed(2mm either side)because these are fitted with arp 2000-06 bolts and with make them unsafe and out of balance,:(
Back to the drawing board.... :(
managed to get rods/pistons about , the hard way lol
well they fit decent ,
added high beam rods/arp bolts , see how utch these pistons hold
you my friend are either very smart ,very brave or completely insane ...i would love to be able to do 10% of the things you attempt
keep it up old bean :clap: :clap: :clap:
