you my friend are either very smart ,very brave or completely insane ...i would love to be able to do 10% of the things you attempt
keep it up old bean :clap: :clap: :clap:
maybe a bit of both :D not hard just a few brain waves ,and bit of adapting ,,away u go
bought a turbo cheep numbers came back as a kkk27 , thought id upgrade it a bit more ,,
thought change it and try this .modifyed ,
bottom pic kkk27
ok for a bit of fun ...unsure how a kkk spools as it says 163 in the hotside
going to try 600bhp so next i need a engine block suport which will fit between sump and engine block
when they come cheep , ill buy them all day long lol,,, always come in handy and i like to test them out
sounds like you prefer working on your car more than you do driveing it which is fair enough for the out comes you get after working on it.
that turbo housing looks bloody massive.
not really i just adapt ideas whilist moter is runing , this turbo is only a kkk27 i just adapted the cold side for more boost
Ok i thought it was yours but this one loks awesome and yours it´s brutal now you just have to paint it with audi a5 white
i pref rough as ,,, save paint /time/ money, dosent matter what i hit/scratch or mark it with just adds to its look ,,,:lol:
also think im the first to run audi rs4 v6 bi turbo pistons in a vr6 turbo , , and personaly im well happy , finaly got engine run , and got a good afr reading little video here, currant tunie is 640cc injector /tunie 4bar, obd1 converted to 4pin maf, 100mm intake,
http://tinypic.com/r/nmdruh/7
had some ecu tuning problems which i couldnt understand which it wouldnt tunie or run correct safter changeing every dam sensor, turbo, wireing loom didnt cure issuise unit i noticed laptop went really bright ,, dam alti over chargeing causeing lots of werid faults , so made it so i can switch from stock ecu to megasquirt ms2 ecu
evern thought it were a boost leak so made a quick tester and pressured engine to 3bar , with no leaks
no just kept with the 16s ,,,as ive banded my own on 225 40 16 , they clear 312mm front discs with calipars on top , about 3/4m clearance ,,lol
