MK3 Ibiza 00778 - Steering Angle Sensor (G85) 49-00
L.R.C.
234
Hello, suddenly my traction light came up, i read the ABS faults and i saw these:
Code:
Control Module Part Number: 1C0 907 379
  Component and/or Version: ESP     20    CAN  V005
           Software Coding: 18946
            Work Shop Code: WSC 11111
4 Faults Found:
        49-00 - No Communications
01276 - ABS Hydraulic Pump (V64)
        16-10 - Signal Outside Specifications - Intermittent
00812 - Brake Pressure Release Solenoid (F84)
        35-10 - - - Intermittent
        37-10 - Faulty - Intermittent
I erase them but immediately throwed, and it cant be erased, this:
Code:
when i go to measuring the steering angle it only reads 0 degrees whatever i do.
Can i test something besides replacing the steering angle sensor?
Can it be something else?
L.R.C.
234
ESP light came back...
If i go to measuring block the steering sensor looks ok, and vagcom lets me to erase the faults but after 15m of driving the esp light is back on throwing this:
00778 - Steering Angle Sensor (G85) - No Communications
as far as i have the vagcom on and reading the steering angle i have no faults, if i unplugged it after 15m the esp light is back...
any thoughts....??????????
turboline
You solved the problem?
