mk3 ibiza cupra......ko3 to ko3s to BT now HYBRID ko3
Apr 15, 2009
2,188
Midlands
Secondary water pump could be the fuse, 30A on far right side of the battery fuse box
Even if it looks intact try a new one anyway, same happened to mine
Good progress by the way, engine build is something ill probably do after next years track rapings
turboholic
CupraPower
Mar 4, 2010
355
Bristol/Bath/Frome
cheers mate. yeah i know about the fuse. i had to bypass the fuse holder as was melted and was working fine but just before it went off the road, it wasn't working at all. could be wiring somewhere else?
turboholic
CupraPower
Mar 4, 2010
355
Bristol/Bath/Frome
tried to fit my coil pack cover and it seems to be fouling on the rocker cover (part circled in red) making it not sit properly!
has anyone else had this problem??
turboholic
CupraPower
Mar 4, 2010
355
Bristol/Bath/Frome
didnt get much done today. few pics of my catch tank, fuel pump, and how it sits at the moment
rear engine and gearbox mounts now ordered from badger5. (should arrive in the week). decided to try the solid front mount from the guy that makes them on club gti but still trying to get hold of him!
engine should be going in next weekend! also need to extend the throttle body and air intake temp sensor wiring at some point.
Aug 8, 2010
700
greenock
It's coming along well mate!! Look forward to seeing it finished and will be keeping a close eye as i intend to do the same thing next year!!
peter_cupra197
414
cambridgeshire
yeah i used to be a mechanic for volkswagen so that helped a lot lol especially still getting staff discount on all parts is also a bonus had a fair bit of help with a couple of good mates on mine though but keep at it love your smoothed bumper also how much did that cost? and also how was it done?
Murdered LCR
Wide mouthed mofo
Sep 9, 2006
6,646
8
Murder Inc.
Looks great mate one thing I will add is that catch can is no good unless it has 19mm inlet and out lets ? Looks to me like the 15-16 mm one which will not help the car to breath
turboholic
CupraPower
Mar 4, 2010
355
Bristol/Bath/Frome
yeah it helps alot getting parts at trade prices lol im doing mine myself but get the odd hand from my brother now and then
got my smoothed bumpers done by an airbrush artist and fibreglass specialist who works next door to where i work so did it for quite cheap! front and rear cost about £120 and then got them sprayed for free by another mate! think he fibreglassed them but have got a couple of cracks in it now so will have to get him to sort it out. looks so much better imo
turboholic
CupraPower
Mar 4, 2010
355
Bristol/Bath/Frome
o right. cheers for pointing that out mate. think they are the 15 or 16mm ones. can i just buy the in/outlets on their own or would i need a whole new catch tank??
Apr 15, 2009
2,188
Midlands
Just use 19mm hose and it should be fine
Use tiny bits of the hose supplied to put on the inlets on the tank then put the 19mm hose on the inlets, the 19mm hose should be a tight fit on the inlets then
Thats what most people on here have done
turboholic
CupraPower
Mar 4, 2010
355
Bristol/Bath/Frome
will have a look round for 19mm connections but will just do as you said berg for now. just want to get it up and running then will sort out all the little things like that
Murdered LCR
Wide mouthed mofo
Sep 9, 2006
6,646
8
Murder Inc.
Try breathing through a straw and see how it is that's what the cars feeling people only do that because the 19mm cans are expensive , at the min I'm not running a can at all and its coming strait out the rocker cover vented to the floor at the back of the engine Waiting to pick my 19mm can up tho ,
Running bt set up I would not be causing the car to have breathing issues
jaypee
174
Are you keeping the current battery mounted fuse box or gonna get rid? I've been trying to find a decent alternative but no luck so far...
