• Hi Guest why not show off your SEAT! (now fixed)
    You can now share your favourite car photos in the new media gallery including embedding pictures from your Instagram account.
Mod advice
Chris232
123
Hello all, first time owner and first time poster here and have been thinking long and hard to myself and can't come to decisions on a few mods
FL FR Leon 2012 CR 170 is the car in question..
LED lights... c5w number plate light size? need to order a set of canbus free leds and the manual doesnt give the specs (any recommendations also before i buy off flebay)
interior courtesy lights size, specs e.t.c i fancy changing these to leds as well while im at it??
bought a set of 19" zito935s for her and wondering what you think for tyre size to put on to be reasonable for looks but also to save a little on comfort??? lol
lowering springs or coilovers, either sportlines or fk coilovers.. pros and cons?? and also 40mm,45mm,50mm drop??
Anyone ever bought anything from rdx on ebay (spoilers) the quality any good or should i bite the bullet and puit a cupra r spoiler on from sere
Thanks any comments or queries welcome
Chris
Daniel M
Blackbelts & Chickenheads
Apr 18, 2013
2,876
Middlesbrough
Not sure on some of the questions but, LED number plate lights are a pain on the facelift Leons. Better off buying the whole unit with built in resistors.
I don't think you'll get much in terms of comfort with 19's unless you run a ridiculous high profile tyre.
Lowering - most people buy Eibach sportline or H&R springs. Eibach gives a nose down look compared to the H&R's which is more even.
Clazzer
429
Stoke on Trent
Here's a list of the bulbs I put in my 2012 car mate. Top two from HIDs Direct and the rest from eBay. I left my number plate lights as I've yet to read or hear from anyone who HASN'T had issue regardless of the bulbs that they have used. I only get an occasional bulb out warning from my sidelights which resets by turning my lights on and off again.
Side light bulbs - W5W (501) fitment - 5W CREE LEDs
DRL bulbs - 27SMD DRL 382's
Fog lights (HB4/9006 type) can't remember what type these were, I know that they are Phillips and are a good match for the headlights.
Sidelight = 501 T10 W5W WEDGE
Reg lights = 37mm festoon
vanity mirror lights = 37mm festoon x 2
middle mirror lights = 37mm festoon
middle reading lights = 501 T10 W5W WEDGE x 3
boot light = 42mm festoon
Rear centre lights = 37mm festoon x 2
Glove box = 501 T10 W5W wedge
elnigel
That makes me nervous. I have just ordered a pair of led number plate bulbs from HIDs direct for my facelift car. Brand is twenty20. Hope they don't throw an error. They are supposed to be canbus? Set me back £15 so they are going back if they throw the light on!
Chris232
123
I was over today to get my 19s on and surprisingly the ride comfort has improved from the 18s, have 235-35-19 tyres on... i cant work it out either but hey hoo one of them things
@danielM where would i look into buying a full unit as stated. i tried some budget canbus bulbs out of the shop today and they put up the error, were in no way branded though so cant state what they where, WHat about fitting a resistor into the bulb holder personally? hard to work out the resistance needed?
thats interesting about the two types of springs, with a sports suspension already i was told i would get a 20mm drop on the front and 30mm on the rear with sportlines
let me know how u get on nigel...
Clazzer
429
Stoke on Trent
Seems to be an issue with the later models, definitely from 2012 on, maybe earlier.
Chris232
123
Thanks a million, no problems with interior lights e.t.c then.. i have just ordinary led sidelight bulbs in at the moment from a previous car.. can work with one error but dont want half a dozen flicking up
just stuck some halfords bulbs in the fogs as i had them lying around but apart from that i have not touched a thing, really only wanted the number plate bulbs changing but might be a challenge by the sounds of it
Clazzer
429
Stoke on Trent
No problem with the interior bulbs mate, it's just the outsides that can throw errors. No real issue with any of mine, like I said an occasional sidelight error which is a quick on and off with the headlights and it goes. Number plate lights...that's another thing!
Chris232
123
is this using canbus leds for the interior as well, or can you get away with the norm? have a thought of putting the rear courtesy lights in red but cant seem to get red canbus leds really only blue and white
Daniel M
Apr 18, 2013
2,876
Middlesbrough
Number plate lights here
http://pages.ebay.com/link/?nav=item.view&alt=web&id=310907959322
Clazzer
429
Stoke on Trent
No, my interior ones are just standard LED's. I thought I read on here that only the exterior bulbs throw errors, interior ones don't cause any issues.
Chris232
123
read that regarding an exeo but wasn't sure about the Leon, bought 4 can-bus ones anyway as a set from partsulike. going to order 2 standard reds now out of interest. pity there wasn't foot well lighting would love to have them glowing red but beggars cant be choosers
Speed-FReek
1,108
15
South Oxfordshire, UK
The interior lights aren't connected to the "bulb out" warning circuit so you don't need CAN BUS error free ones. Probably because you can easily see if any interior ones have gone so pointless including them on the bulb check circuitry.
Chris232
123
yeah all ordered up now. just number plates and sidelights now if i could bring myself to click the buy-it-now button
Feb 6, 2014
1,325
Lincoln
Speed-FReek
1,108
15
I stumbled across something interesting the other day regarding LED number plate bulbs when I had my car hooked up to VCDS. I'll post up a screenshot when I'm back at my computer.
Speed-FReek
1,108
15
So this is what I found while looking through the VCDS coding options for my BCM the other day. I would be willing to put a few quid on the table that this setting probably allows for the fitting of LED number plate bulbs without triggering the bulb warning lamp in the instrument cluster.
I don't have LED number plate bulbs fitted to my car (yet) so unfortunately I can't test out the theory just now.
AT Designs, Custom Badge Design for forum members
