Mods for custom stage 2, advice please
s_delday
Hey everyone, I am going to get a stage 2 custom map on my mk3 cupra, I already have most parts but wanted to check before everything goes on if anyone recommends anything else to get!, mods when I get the map will include:
-cotton air filter
-golf 180 injectors (according to previous owner, anyway to check?)
-forge 007p recirc dump valve
-2.5' turbo back de-cat exhaust
-forge front mount intercooler
-4 bar fuel reg
-n112 bypass
-n249 bypass
-bolt down coilpacks
Yet to go on the car:
-vr6 clutch (brand new)
-g60 flywheel (brand new)
-beach buggy turbo 15 psi uprated actuator (brand new)
-sytec in tank uprated fuel pump (brand new)
-ko3s turbo
-forge silicone TIP
PLEASE, if any of you can think of anything else that may be beneficial for me to get please don't hesitate ! Will be going to R-tech for the map as heard great reviews and are fairly close to me
Jun 29, 2001
536
Surrey
This won't make a jot of difference to the map, but some good brakes are recommended! :)
Not sure why you need the Golf 180 injectors, though. I've been on K03S since 70K miles (now at 160K) and have been using the standard injectors without issue. Same goes for the actuator.
dean66
126
Elgin Morayshire
Forge cooler will restrict your power as not that great for the flow.
Golf 180 injectors asleep just the same aren't they. You could fit injectors from bam 225 engine but standards will be fine for you.
Sfs supersize tip will be much better than the forge one.
Pretty sure rtech will only map car with 3 bar fpr unless the 4 bar one is really needed.
A few things for you to consider
s_delday
Golf 180 injectors were down to previous owner and there was no proof so just going by what he said, I am now going to badger 5 for the map and told him it had a 4 bar reg and he still went through with booking so think I'm fine with that, thanks lads will take in to consideration what you have said
