I have a really strong feeling that after getting a new rear drivers side tyre, by a mobile fittier, there is a lot more vibration feeling through the steering wheel and seat on all speeds and surfaces.
Its not been balanced properly. He may have put new weights on but it still maynot be balanced. The same thing happened to me. I took my car back and got the wheels balanced again and everything was fine.
All new tyres need to be balanced when they are put on a wheel, even a mobile fitter would have to do this. If they can't balance it, get them to pay for somewhere that can.
If you have weights on there then it should have been balanced. I'd give them a call and see if they can at least give them a check for you. A weight could have fallen off, if the wheel was wet when the weights were fitted then it could possibly have come loose.
had this on a car, all 4 tyres slashed while in uni, mobile unit came out, shaked like mad after, eased off a bit and i never got it seen to for long time, ended up having gearbox, drive, bearing and brake troubles!! could/most likely contributed to it all.
