davemotor
12,507
9
Belfast UK
promised to put the pics on - commercial (lorry :lol:) mudflaps at under £15 a pair
thanks to daveysfr for getting them for me :clap:
Details please. I need a set. Are they easily fitted or is there drilling in to the skirts required?
bog standard lorry/trailer mudflaps mate. a pal from scn (daveysfr) got them for me as the place has them (Givran carparts, Newry) is 40 miles away from work. if i can help you, i will - our van is in Newry every week or so.
used 1 existing sideskirt screwhole to anchor, then lined up and drilled a couple more into the splashguard. straight eye and some patience ;)
not pretty but very necessary!!!! :lol: cant even drive it after a clean without getting tyre dressing all up the sides, never mind the s**t and stones off the roads [:@]
if only SEAT would do something proper :(
I would have mine in a bit more than those are - those stick out a bit more than I would like, but they are not like Subaru rally styleee which is good.
Ideally there would be OEM moulded flaps, but alas, SEAT see fit not to supply them to cars with the Aero skirts :(
Not a pretty solution but at least its a solution. I suppose if you had the time you can cut the mudflaps so that it followed the contours of the wing.
Might be interesting in a set (the other option was to put rear ones on only)
Alex
