Not many updates or time /
resources spent on the car
just finishing putting the final parts together for my R32/TT front suspension setup
I have the quickrack which is 2.5 turns lock to lock as opposed to 3.3
Cast iron wishbones eliminates the inherant understeer which all MK4 Golfs suffer
Also means camber can be bang on 1.5 degrees - they are a massive improvement over standard wishbones and they also offer:
* An 0.5 degrees of extra adjustable negative camber (If car is not lowered it is -1 degrees and more if lowered)
* increased track width
* These are MUCH lighter than stock lower arms - handling is massivley improved in the handling department with the weight loss
* stiffer bushes= more feel and a better driving experience!
* the best thing about the TT wishbones is that they already come with the bushes pressed in when you buy them brand new from the
dealers!
* price breakdown:
Ball Joint Nuts: - £0.50p Each
Amount required= 6 total, (3 per side)
Part Number= N103 320 02
Lower control arm: - £104.18 Each
Amount required=2 total, 1 per side
Part number=8J0 407 151 D (same part number for each side)
Hex Nut to attach ball joint to hub : - £1.91 Each
Amount required= 2 total, 1 per side
Part Number=WHT 000 785
Ball Joints: - £34.00 Each
Part number= 8J0 407 365 (LEFT SIDE), 8J0 407 366 (RIGHT SIDE)
Ball Joint Lock Plates: - £4.57
Amount required= 2 total, 1 each side
Part number= 8J0 407 175 (176)
