My engine bay
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
Here is my engine bay as t sits at the moment :D
[/IMG]
What you guys think?
MikeA
MAF Destroyer
Nov 14, 2005
92
Northants
Looks fairly similar to mine lol
Only things that stands out is that the filter is open to the elements - you considered getting an enclosed? Or making an airbox for it?
ttothec
349
Reading
is ur filter supported in any way?? if it isnt there is a good chance the maf will fail due to the vibration
looks good tho
super_stylin
207
looking good matey, in my opinion open cone is better, more noise and i have no issues with it
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
looks good tho
No the airfilter is quite firmly placed so doesnt shake too much...think it sould be fine.
And I had a cone filter before this, and it made more noise, however this one makes my DV sound much louder...and liking that more I think.
Dont think I will be making an airbox for it...I just take it off regularly to clean it...will be fine
And the engine bay not even close to being finished...[B)]
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Your filter sucking in hot engine bay air = lack in preformance. do you have a FMIC? I wouldnt worry to much as this should keep it cooler enough. Most people on here who run an open cone run them without a heatshield. Myself included :D.
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
FMIC is the aftermarket intercooler right?
If you are talking about that no not yet...I have only had the car for 3 months now and buying it set me back quite a bit already...
so gotta save up a bit again and then gonna continue modding it.
ttothec
349
Reading
dont want to start another airbox/cold air intake vs open filter debate... i run an open filter and havent noticed any drop in performance
the theory is that the heat produced by the turbo is drawn in by the open filter in the engine bay, and as the air is hot, is less dense, so less oxygen, so drop in horse power.
someone i know actually did an experiment where he fitted countless air temperature sensors in the engine bay of his car, and measured the temperature. when his car was sitting still... engine bay temperature did rise considerabley, which would effect the power
but as soon as the car was doing more than 5mph the airflow throught the engin bay was such that all temperatures dropped to ambient temperature (or very close)
basically... i wouldnt worry too much about an open cone filter
Mar 10, 2005
1,439
Walton on Thames
but the air from the air filter is going stright into a red hot turbo anyway...
i think heaksoak in the engine bay only really applies to n/a cars.
ttothec
349
Reading
the turbo is 100's of degrees C, the air going through doesnt get that hot
putting hot air into the turbo just means that the air intake temperatures are gonna be slightly higher
these are just estimates:
eg. air into tubo 16degrees = air out of turbo (into engine) 30degrees
increase air intake temp
air into turbo 25degrees = air out of turbo (into engine) 40degrees
