My leon cupra 305 whp ... 340 engine hp.. 50 kg*m
Blade
1,388
33
For this reason i have reduce the pick pressure a 1,75 for the standard k04 turbo and continuos boost of 1,4 bar until 55000 rpm and 1.3-1.2 bar until 7000 rpm , but i want to know if your pressure of 1,35 is costant until 7000 rpm or no...!?!?
Don,t have a boost gauge and not logged it so i can,t answer that one.
Which type of engine mod do you have install?
Nothing too dramatic - HPFP, Dbilas CAI, Full Milltek and GIAC mapping. Run standard D spec D/V without any issues.
Blade
1,388
33
pistons are forged as standard mate. dont really need to change them till your going quite a bit past 400hp.
Race cars in the States are pushing 420bhp on stock internals so i think there,s no problem there.
Poverty
Dans isnt a cupra so I dont THINK the rods were as strong.
This might be true, but I cant remember whther all 2.0TFSI's come with the forged mahle pistons or not. I can always find out later tonight if I get some time.
I think also the audi s3/tt-s engine is stronger than the ed30 and cupra ones :think:
Need to read up on all 3 :)
cupra-tfsi
31
Info Intercooler
Hi guys.. are there a people that have install s3 ic + FORGE Twinintercooler???
Now i have S3 core on my leon cupra tfsi , i want to know if is a better solution s3 + twinIC forge.. , Now i have high boost setting and i want to save engine with 2 ICS.. :shrug:
Thank you for all
DanGB
Who need's a Diesel....
Feb 12, 2006
3,772
London
The Pistons and rods are different in the BWA (197hp) than the other k04 based engines. Mine are Cast pistons, but still good for very high numbers. Rods were pretty weedy on mine.
Poverty
Thank you for all
People have done it before, yes.
acyv
I have 365 hp without changing intercooler and turbo, you must have at least 410 hp with those installments...
acyv
In cupra never and ever use twinterintercooler. You must replace the original with bigger one only!
