No just the tint spray can be removed.
The above look a bit pinky to me. When we tinted my mates standard lights they looked fine, the trick is lots of light coats with a few mins in between that way you shouldn't lose the detail of the lights.
My VR lights had a whole can sprayed on them followed by about 5 layers of clear and the detail is still very clear through the paint, should be the same on the standard as they are both made by hella just one has red plastic the other clear.
You will use far less tint spray on the standard lights to give the same results. Tint your standards as a practice!
did you use tinting spray for this or proper paint mixed with lacquer and where abouts did you get your tinting spray from??
I managed to source mine off eBay ( you need 382's)
As for the bolts, I'm down two now, was screwing when I managed to drop them, I'm prob going to pop to the dealers and get some as I have a number of other bits to get
