Mystery sound outside of car after engine turnoff
Alex_280
42
So this question may seem so mental that I will be committed, but... I'm not looking for a problem, as it's just a very faint sound that is causing no issues, I'm just curious as to what this is and I'm hoping one of the boffins here can answer it...
After getting out of the car, without locking, there are very quiet sounds that I can only describe as the noise of a dvd player/ disc drive being accessed, not a mechanical grinding noise but a series of chirps or bleeps. They appear to come from the front around the engine bay and last about 5 minutes, occurring every few seconds. They definitely sound "digital" in nature. Do I need to see a psychiatrist/ is my car trying to talk to me?
It's an MY16 Cupra 5 door. No optional KITT or under bonnet budgie.:blink:
hutchy14
65
Im sure the majority of vag cars have an electric coolant system which stays going around 15-20secs after the engine shuts off so it could maybe be that but I know the exact noise your speaking about
Alex_280
42
:rofl: Thank you! It's good to know I'm not going mad. I have noticed that it doesn't "tick" loudly when cooling like older cars so this sounds right! Cheers hutchy!
niggle
Rollin' on 17s, baby!
Jan 28, 2014
459
Huddersfield, West Yorkshire
I'm not convinced it's the electric coolant pump but I have heard sounds similar to those you have described from my 1.8TSi FR (EA888 engine).
Either we are both going mad or both quite sane. :)
hutchy14
65
Yeah my 60 plate bocanegra had the ticking sound so I'm not sure if maybe the newer cars have the electric one
MyLeon
349
My neighbour came round to ask me what the noise was! I hadn't heard it up until then. I have no idea what it is, but one day I'm going to stand there with the bonnet open and find the culprit
2015 Leon ST FR 184 DSG
yozza1987
Leon Mk3 Fr
Sep 3, 2013
110
Worcester
I know the sounds. Think the clicking is relays as for the other noise all I can think is coolant pump. My old Ibiza 1.2 tsi made the same noises
Brady93
248
33
Worcestershire
I have a similar hum too but it only lasted 3 or so seconds, sometimes just opening your door with ignition on would start the noise, even my old 2003 Ibiza did it, I always assumed it was the door locks or something? Maybe I'm thinking of a different sound to yours? But the description of a DVD player is spot on!
Sent from my HTC One M8s using Tapatalk
Dt-spd
246
Rugby
its most likely to be some of the valves ( throttle, EGR etc.) doing a learning/cleaning cycle. Most modern cars do this after the engine is stopped.
chris94
Essex
I too have this noise! I also had it on my 06 Fiesta, as lots of others have mentioned probably something to do with cooling!
Madhatter
141
12
Sat on arse
Modern cars make some odd sounds after you've turned off ignition. It's typically the ecu switching on the cooling system for the turbo, vents closing and various sensors;all tripped by the charge in your battery and the ECU.Don't worry about it. If you see flames, then you need to be concerned.
Aardvark
242
Leeds, Yorkshire
On my last car I had an owl that hooted for about 10 minutes after switch off ( Citroen DS4) and my FR has a dolphin that clicks and whistles for a while. On a separate note, I bought my lad a new Beko fridge freezer and his came with a hump backed whale.
I am convinced that these sounds are coming from a air con or coolant circuits as gasses contract
Alex_280
42
Speaking of animals I feel a bit less cuckoo after reading this, cheers :D
alex.o.d
10
I have a 2007 1.4 model leon when the engine is switched off immediately after I get a bleep noise for a second do these cars have an alarm I have never herd it go off or seen it around the engine bayb
Sent from my GT-N7100 using Tapatalk
dw911
1,036
7
You might have more joy if you post in the mk2 forum, someone there will likely be able to give you an answer :)
