some have but you need to put resistors in the plug to fool it into thinking it is connected and working
Is'nt the N249 there in case your dump valve fails and if so, is it really worth bypassing it?
dont need to put resistor on. just leave it plugged in. remove the vacuum resevoir completly. no need for it. leave the bracket in place where the coil packs are and just leave the n249 valve on. doesnt throw any fault codes at all. only need to resistor it when you actualy remove the n249. but may aswel leave it pluged in as you cant see it anyway when its under the cover.
remove it all... all u need is two vac hoses from the 2 outlets under manifold. one to the fuel pressure reg. one to the top of dump valve. easy as that, get rid of all the rest of the complicating confusing vac lines and stuff. just leave n249 plugged in. simplee.
