I did the H&R 28mm Front & 26mm Rear Anti Roll Bars part number 33851-4 but I have the 5 door hatchback so fitting was not an issue
have a look at DPM Performance that is where i bought all my suspention kit and they offer great advise in my opinion.
Reactions: nd-photo.nl
It seems to be an ever increasing minefield re the "fitment" of many parts these days.
What a nightmare, can you return it ?
I sold it as it had installation marks on it. I did not drop the subframe or remove any control arms, so it was a good game of snake and tetris getting this bar into place before trying to clamp it down on the mounting points.
Lost a little bit of cash on it, but thats ok. You win some, you loose some
Reactions: Mo_86 and tracktoy
I managed to get some confirmation via 034 Motorsports as to the fitment models, but the locally available option is Aus are either
- the same size (current is a 21.7mm bar) with 22mm solid bar being the readily available - A$350ish (Prospeed)
- Bigger at 25mm, but MUCH more expensive A$620 (Integrated Engineering)
- Best option but stoopid expensive at A$890 (034 Motorsport) with an extra A$250 for the replacement links .....
And given that none of the suppliers even know what a Cupra is an list it as a model that the var fits, it makes returns more difficult :banned:
My exhaust cutout control box has 2 remotes, but it seems the previous owner did not know what size battery fits in there :ROFLMAO:
You need type "27A" batteries if you have these kind of remotes
AP1GczMPG6HrW3xLzpWaDl3s9QVgtvPvkULn4HEW12xIsrbWPuuU8LcM04LwHrdFN_9lr21FrLk4SKwxLvudx5lFc7cpQhJrJvhkqqVWfHeJtYrCgFRM4ZZPQpeY_S5QKrF-iW4mMtc67TCZUx7ehKZ3gMibgg=w1920-h1080-s-no-gm
Bought a new low pressure fuel pump. This was a very easy swap! And some good insurance for a proper running car
I opted for a Hella unit
AP1GczNvBBv4H4zF0vwE_H5YjBuvsP1yhmVz7XymNL3COkYy58hFyoUBS8IsiOpeUOwi-2abqtx-qPU0nPOmLDdW7TTi-qtRejy5dOabHVqkxn1uxFDylgTcsSLpamITqwVIGic-lt_puvIIrtF4RB2JhBkg1A=w1920-h1080-s-no-gm
The fuel pressure regulator sits right next to the pump unit
AP1GczPDHMy5d9xDm-2QgRbBK3sgcGRvMTwXYrN15SFRmiZCykBrYrHfhXDzFg6t8Y2jSoo5rNXV0CEj6r_ary-NimU_0S822JPu62VtHgpw5CGllSkT98XPdry32pbM6MxVXaD1HaxtkNXcVHaKXIgF8VRdhA=w1920-h1080-s-no-gm
A very simple setup
AP1GczOpjTmIf12rk_3vNo7dBAxDx55OW5wFhxnkkcC3fPu9SKCILU8erNybMPywNIik_8ibyjlRO6UXgypYbRaZcfNOn77RlIUeKh_io4dFAhwIWtBepOpyi4Eg3oMU16UUIjSTc_wzTshN0HMbX1N7iQ3yBw=w1920-h1080-s-no-gm
AP1GczPY4SYNAg8ZTblF5Spkozd95_vT5_gKR2K7owFkIZtHwkRi35E9Y9iMv1P7GJaeyVPmPQtm0rIEGicNBiK6qXTDHTAr6BekyW1fRYJwu4DHXitsUy27fyYCUT7nzC6TKMb9vRqaUQK1LQGRi9oL1lI40Q=w1920-h1080-s-no-gm
AP1GczNoXKvZU5Dmo7LX8yeVETvnEUXcNQS6dJS3j7QnwWE7JtEhjbYTXyxqJFpZnBWP_FRRATKlaeZ-E0vdafcFhboXvXkHIPYyrWuzIoa1rUAVldGtj0b0dlVdmb0onIwCkp5HxIeU1GX6rqdt53Ak-eX8ng=w1920-h1080-s-no-gm
Quite some sand, always clean before you swap out the pump! The flap that I made with the alubutyl works perfectly as it allows for easy access
AP1GczP46kXT_Zyq-JlMmcU6ML28wysxhb39ukPFd7PlPp4aIuRHoczctE6rjK4-e6XjyOPVyWPEH49UCoM249cI6jtH_Un-V9I3-aJAjow4GNi72zkhTYcgsZUHsJ_zOaiz5TWLd_HgaS6Ls7yyKf5pm2FI-Q=w1920-h1080-s-no-gm
AP1GczMDWLD1JPYrkdxJE1PnYhq2IuDeJQjFr_Zaz3owmKEnzT_cKdnz2UwhWMl3tOcIhlMVPGFy5NYUq1kw1Ip6-D7RddfrEujwAgUWUoSaE8NoH5RGAkyAPmXDyNqgrsG5-TqaGxNpLWaBqHRHXqmXXX7W5Q=w1920-h1080-s-no-gm
AP1GczPZnKBcVGob4_r04BsymNCftnrQdDpTGYklup4uz7DKZiJr2Pa6O4xxdxnNSthtZE19ENw_K-nYJBaZI5UOONFod0LEsgLByq3gtBINTJZuvUWPR4TD0HaWC7rWzVY3OVXoRu7L0wfFouRGgCOisRSSuw=w1920-h1080-s-no-gm
I had to have the revo pump fitted as I was suffering with fuel starvation on some inclines on the Cadwell Park track.
Noting on the road just when pushing the car to the limit on the track, also had to have a software upgrade to support the new pump since that was done I have had no issues.
  • Love
When doing an oil service earlier this year, I noticed a lot of gunk around a sensor very close to the oilpan, which identified as an oil pressure regulator valve. Instead of fixing the leak with a new O-ring, I opted to replace the valve al together, because I use almost every occasion to slap new parts on :cheeky:
New Gates oil pressure valve
Partnr: VVS263
AP1GczOlTHp0F1L_4K3TaWz6TdMGasdebvQUsX5SWh3p3E97PZkhypHdugTdkhIYCOlEnoB64tj-7CcrsksnlgmUahQpnQlOnGb7pQsV6Uv8bj5oqn8Lx2eLW50v6131bkzmZiK8ri0h6mSYBbp41Z0BESHZsQ=w1920-h1080-s-no-gm
AP1GczPxiNSbTSdM09LdEIoIJRQQ5KYz4nMrJyzCciqh7VkvLLhwjDC5mI4KDHlhmSsn7xk0vbuG3RUfILxRzDpMNx77vstwwic1miWWRSYc-1fycUF7y8LpgnSYfcBgL3d2Cau9a_PVor0zP13TTUWEYpw4GA=w1920-h1080-s-no-gm
It has a builtin strainer, probably to retain oil pressure
AP1GczOiYgyxqAEWxvmRXA6qD2wPt3cIyO5W0Vw0Po21GErQuqin7NF-QKKmJCyWLNPiTXzYWrWSj6VqapHCKB2j30pg04e0Bfa9K5yFapAD3_92xY7YARrJ74ofQxii-2MWIEIW2WrwSMtfjRotoKqNgm0g4Q=w1920-h1080-s-no-gm
AP1GczM7SImc0K3er7LY8EF15a2zHiGE0vvSTkLMT1C6ioQfUFsYv0XhuBS5yf9vSqqx8SMnHud-0gO5i9vDlqRxseBQ_paW2MP4iabq7d1FmsHq9bj8QIyBDSzShTQPb0p9pbfHkp7lScsdtytYmkh7El9nvA=w1920-h1080-s-no-gm
And then disaster struck, as my good as new IINA tensioner decided to break, well the cast nut on it at least...You need to remove the aux belt to gain proper access to the valve
AP1GczPyj3ko7UgG-yolkorkPub8-blcliaP9lW0GRBiil_vBZmQg9Xk7KVyhXS080LFnsqJGEd-U8W8MfkNlGuYakMxekQquKiCK-hCCiI1FqeeKSxeaa5AMPDJITUA-ONntuR879m7LdBq8M7XZyMI31wjHg=w1920-h1080-s-no-gm
AP1GczOOv4NdZZXP8ufF5HqBXWxnWvshxczyWMz_7-LzqfQh9OqwBpotfP13trhMLyhJbbWua7ler4QLHs_71seSb7q_m2luXq1USBgqYvXBsEzlN5SZKIOfyI41g4ag_B_QZkO5IlWHRhGdg48kRhc8G4tU9A=w1920-h1080-s-no-gm
AP1GczOqrtZCueznkCQ_jZmJgMTETolT9hCqpjax61q56Fot3TFiKCUFmVeA7yoW4gJR8dZbJMuqwMkfDjWThsKmUs2GoPRDQbesOhRLTR--RTNEdjSwqCJYJA3seAZixjT5ip8K1Bzdt7KJrp2v8RzS2HMbjw=w1920-h1080-s-no-gm
Time to order a new belt tensioner I guess :shrug:
Reactions: tracktoy and Mo_86
Couple of days later, the new belt tensioner was delivered. This time round, I bought a SKF tensioner. It does not have the cast nut, but relies on the bolt of the pulley.
Looks well made (y) The thing in the back is a shift linkage upgrade for my girlfriends car (Opel Adam).
AP1GczODeAm4tRfon7agytaO4uCvRirGu3S5NQ8IrVbMCDlsR0cQcd9sLzlHjuvM7qg4QvCQ0MdgNknHB3sypvoAa61liyqIL6K4b4LHopIcka6Rz9-J17oVS1ThmZj8OvA939TgacaL2rVUApSgfE_-jbLmvw=w1920-h1080-s-no-gm
AP1GczNeHVpXyFKiYo51Ue7xquLyGtdMwlCpImle9URCYq6GbX8sEvLzZNDXQORvavzHUQr0h9aJ2S7SizvA2_iR6cvYJ5f044KtDJhgKReqEOZJpe8jhJfPufPqCq2zD8Q2qGAB4N_RPvRoFdjCVuB4JZnQUA=w1920-h1080-s-no-gm
AP1GczMxtIUsgzvyX31v0k-H9xzpBXEiO_71lrdL7-qiLrPcmAuCWb8l677PaC77aEMN7t9H3GjjTk0LBY4medSfqpj-DKzTHR3M_UzHbot4amZkiPakisnUHggjrTM_ORDnsohFo39dkiI2tmsuJrWCrxHEKg=w1920-h1080-s-no-gm
I was able to release the belt tension using the nut of the pulley
AP1GczOaufAxxr4Ils2hYTvlmliPbm2PTVhny375bNZXKKz8clTEE_KTEBZs2dsStDLThb0wwnOeXsGWnxVI-ICpj_tIwUh_4JUHbrQyZqSsjTtBpy7ACL73wUIT-HkY71vi9LPJZ-OQV2xAAZ7INcdYi-l_JA=w1920-h1080-s-no-gm
New vs almost new :redface:
AP1GczN6k-CuwOcpeSLbXKqRR7ir9MCUYOw3pLLkQyi1654OTx51avokq5kUDmLmwr_TWqFM-zUIIJ2I5Sf7WQjciUjc0rRC6wOnLRL8lg5Se-lckog_pr6cvFgRhK_Mpx4aTJ6HIEynvMRn7AOmlZb8ETn-DA=w1920-h1080-s-no-gm
Reactions: tracktoy
Then finally, I was able to work my way to the leaky oil pressure regulation valve
AP1GczPU5kvLpVihZ0Dc4bT2mfpUh9IFBlIZbDYRolDHReOg5B6l7ZekYZH93f1XxH-PE4tJsrD63_F6KWXUVN5UsJx-miA0G4LZ0NEmF63dywslTx8cmuk7nLGlJ80aCQhDBbGAe0tntLclLfUJJP05LMGrPw=w1920-h1080-s-no-gm
But where is it, you might ask :shrug:? Its right there :) You can clearly see oil & dirt around that area.
AP1GczMGJ12gZembNwAnWCIeNfn8aJKEjrD0RPrnjs9AC2cyomKJcXSy333jv8hcIMluyJOrIeiRVdBzqmDy8mMA_Guyq7yEgyvjsMABSvDSTzWWMxePmuTWs0klkw0r7n80j3-MmRfxVEWUhsheFuSSMoDDgg=w1920-h1080-s-no-gm
Disconnected the connector from the top
AP1GczNwTHHKqJ1C7pblrxYc7ULcG6OV0TGcSCMkfnLJ_7LrKuldc4z9_smYIUxuT6IJ-NQ_b30OoXeCiIk813v4ZZsIs02DO9_McPOeLtsJoUI-q2EN_yf_bHj8hZLyqPoH3Vjj7Vra0kaN6YoReq_Op_onAA=w1920-h1080-s-no-gm
This is how it looks from the bottom
AP1GczNjW474ikablsl_gG4IaYYevpct-Fk3sb1aojfXKOldjltSAWV3Oz_XmmOaOlq6vGDa0Inuc4JGhKKHeKaqSCS-MOv13CEth1vEo9lOxdpmM1xelXCAM2UzFwpzB1M_J3tnhwvZxLcC_7EcxRXhp4L2UQ=w1920-h1080-s-no-gm
A little zoomed out, so you can see exactly where it is
AP1GczPcAZBeGHdMRY4ZDXDhTGP7QhrFzXJqNVHZ5or2wYPBBdjqSsvxlmmwQFuzYIYZ5lANobGCVC4R2efvcI3-lFMQ20F3o9r6IACkS6VsH5U9uQQut9YmFij-dL6AsAys1DVMvvnT5ClL8N6XQLkXR8-LXg=w1920-h1080-s-no-gm
Thats why you need to remove the aux belt
AP1GczNIzHSJGdBDxdV43PSBT-ucisy8mxkpnmRMSk7oTEk5vUyfT5EjR_U9eBwm2LAl6lEGYsta60g2E9oDeTk15ot7Ddt8yBTggNCvqPj0yvzXYW0kpYwl0SGVtw56koGb-IqQXsQhKG9JZZTkpLDWwbJ2Qw=w1920-h1080-s-no-gm
AP1GczPi3UUQxH30JGU-KSeb5z3g1gxqBg4OPzsgalTZRvFWznBUeJBVhSbk7XChYwKxIBmsEYfCXOmI_v4f__rHTRTCl-Z1O17HbMkQd7SgcEBzgxShigHwiQZA1zRtSmpKwKG0-hWW2TzIgvvhEkeyF0q39w=w1920-h1080-s-no-gm
