Oi, that wasn't very nice. I just don't want it to look like it's leaning forward!!
It won't look like that. Depends on which engine size you have. If you have a 1.4 then I definitely recommend the 60/40 kit as the 40mm all around kit makes it the front look still sky high.
Anyway, as standard, the front is 20mm higher then the back, so the 60/40 kit will level it out.
Check ibizamk2.co.uk for photos of lowered Ibizas.
cheers for translating! sorry was a very quick reply...
Searched for that site earlier and found all the pictures. Is a 40mm not much for a 1.4 because its a generic kit and the engine is lighter than the other larger cc ones???
Reckon a 60/40 is what is needed then! Cheers for your help czech
Believe it or not but this is my old 1.4 lowered -40mm all around using a GTI kit. As you can see it could have done with another 20mm in the front (or even another 50mm )
