need help - Pictures required
Jun 7, 2006
2,983
Norfolk, Norwich
Ok
as some of you might of read i have had some Spax fitted. i think they need a little fettling with to get the best out of them but im worried about a few things
Can everyone who has lowered on coilovers do me a favour... i need about 4 pictures of the car :)
1) a general side view
2) a Rear Wheel arch face on (to show the gap between arch and tyre)
3) a Front Wheel arch face on (to show the gap between arch and tyre)
4) Under the car aimed at Sump Guard.
Reason i ask is i have about 1.5" on rear tyre to arch, about 10mm on the fronts and the sump guard to the ground is less then 4 fingers.
ill get you all pictures in a min but can other post so i can make judgement on changing it :)
Lee
st10587
i only brake for cake!!!!
Oct 4, 2007
3,669
Hindhead
thats how mine is if that helps
st10587
Oct 4, 2007
3,669
Hindhead
your cars not level. you should wind one coil up a bit to level it up. the rear i just have it as low as it can go.
st10587
Oct 4, 2007
3,669
Hindhead
ah ok makes sence. it looks about the same height as mine. if you want to have the front and rear as low as each other then take out the adjuster cups.
Jun 7, 2006
2,983
Norfolk, Norwich
im just worried about the front being to low... i might i cant get my hand under the sump thats so low.
im thinking of going higher but im not to sure how much higher.
but like you said yours does look lower
Lee
st10587
Oct 4, 2007
3,669
Hindhead
just checked mine for you and sump wise its about the same as yours. i have not caught the sump on any speed humps yet. even driving up onto car ramps and 4 poster ramps at work i have never caught it yet
