need help traction control system
dean r
just had new tyres fitted to car and now my traction control light keeps comeing on when wheels are not spinning but if i turn system off engine spins up fine and any help cheers
Ferryman
1.8T Goes Like Hell
Oct 23, 2008
208
Helsinki, Finland
Check with VCDS what kind of reading the wheel speed sensors (especially the wheel which got changed) displays. Most likely one of the sensors got damaged or disconnected during the process.
dean r
Would it make a difference haveing bigger wheels on bk than on the front if you know mate Cheers
Ferryman
1.8T Goes Like Hell
Oct 23, 2008
208
Helsinki, Finland
The difference in circumference between the front and rear tyres is so large (12.1cm) that the ABS/ESP controller sees the rear tyres spinning ~ 4mph slower than the fronts. Even the car is FWD only it will mess the ESP.
The only way to fix this is installing tyres with the same circumference.
Or disable the ESP.
