Hiya all.
While searching for a solution to a few niggles with my SEAT I discovered this great site so thought I'd ask you nice chaps (and any chapettes) for your advice.
After 3 years great service from my Seat it has in the last couple of months developed a few faults and being a poor student I don't have the beer tokens to get a garage to sort them for me.
My car is an 1.4 Ibiza 51 reg (mk2 facelift? mk3?) Only has 50,000 on the clock. And up till september has been serviced regularly.
The problems are as follows....
1) Water temp on the dashboard is usually not functional, occasionally it will go up to 90c for a few minutes then drop back down (I'm thinking a loose connection). I have checked the connection by the water overflow header tank thing, (the bulbous thing with g12 printed on it) (stop me if I'm getting to technical) but that seems to be fine..... is there another connection somewhere? if so where? (a pic would be helpful)
2) External Temperature on the radio/ac display just show's as a blank. I have looked for a loose connection in the temperature sender in the passanger side wing mirror but it looks fine. What else should I check?
3) Occasionally (usually when it's cold) I'm getting an intermittant fault with my ignition. The car starts fine, but once started will immediately stall unless I push down the throttle. It will not idle. This tends to clear up if the engine has been running for a while to warm up. Could this be a problem with the Air Inlet Temp Sender? If so where do I find this? (again pictures would be helpful) I've had a quick look under the bonnet but could only locate the MAP sender.... is this a dual function unit?
Thank you all in advance for any help/suggestions.
