TimD
472
Tonight will be my first time out with the vag-com, just wondering what and how to check things.
Cheers :)
Tim
Once you get connected to the car, just do an auto scan WITHOUT airbags. See what it comes up with, copy and paste any codes into Word for future reference.
Have a read of the Ross-tech site, maybe download teh user guide and print it off.
Gavin
Is it in the centre console then or is your plug just a bad fit?
I got it on, no errors apart from ABS which i new about anyway as i have the sensor disconnected atm.
I did some quick logging, i was managing to pull 144g/s is this good or bad MAF wise?
Thats a bit more than my mates chipped A4 so could be good. What does it drive like. I would think a practically 200 horse Ibiza should be pretty balistic.
Only way to be sure is to fit another.
Other point to consider, different sized MAFs will produce different outputs which the ECU then converts to airflow.
If you put a bigger MAF on a car, I reckon the ECU will assume the airflow has dropped and it should underfuel.
If you try a new/remanufactured one, make sure it has only Bosch(if it is Bosch originally) numbers on it.
Gavin
Right then guys and girls, here is another couple of logs using blocks 115 and 118.
Code:
	Group A:	'115
		RPM	Load	Absolute Pres.	Absolute Pres.
	TIME
Marker	STAMP	 /min	%	 mbar	 mbar
	46.35	2960	117.3	2450	1590
	46.85	3080	138.3	2430	1850
	47.35	3280	152.6	2410	2050
	47.84	3440	160.9	2400	2160
	48.35	3640	163.9	2400	2240
	48.85	3840	165.4	2410	2270
	49.35	4040	163.9	2420	2250
	49.84	4240	161.7	2410	2220
	50.35	4400	158.6	2380	2150
	50.85	4560	156.4	2340	2100
	51.35	4720	153.4	2260	2050
	51.86	4880	149.6	2200	1980
	52.35	5000	148.1	2150	1940
	52.85	5120	145.9	2140	1910
	53.36	5240	142.9	2090	1870
	53.86	5360	139.1	2070	1870
	54.35	5440	136.1	2060	1850
	54.85	5520	133.1	2040	1820
	55.36	5600	131.6	2000	1810
	Group A:	'118
		RPM	Temperature	Load	Absolute Pres.
	TIME
Marker	STAMP	 /min	°C	%	 mbar
	58.57	3080	48	99.2	1470
	59.07	3240	49	82.4	1860
	59.57	3400	50	83.9	2070
	60.06	3600	50	87.1	2200
	60.57	3760	51	86.3	2260
	61.07	3960	52	94.1	2250
	61.56	4120	54	98.4	2240
	62.06	4320	55	99.2	2190
	62.57	4480	57	99.2	2130
	63.07	4640	57	99.2	2080
	63.56	4800	59	99.2	2020
	64.06	4920	61	99.2	1990
	64.56	5080	62	99.2	1940
	64.97	5160	63	99.2	1920
	65.47	5280	63	99.2	1890
	65.98	5360	66	98.4	1870
	66.48	5480	66	99.2	1860
	66.96	5560	67	99.2	1840
Apparently the above aren't too good :(
