sambo19
sambo
Oct 20, 2006
104
worcester
just took the dials out of my ibiza gti to see what bulb i needed to replace to light up the rev count when i thought it would be a good idea to see why my abs light wasnt lightin up, seems the previous owner had taken it out. so i swapped the handbrake light with the abs and let and behold the abs light stays on. i have my mot in about 2 weeks time and as im new to seat i have no idea how id go about sorting the problem out. can anyone give me sum info?!?! cheers
Take the bulb back out!!
Sorry, couldnt resist, if you find someone who's got a product called vag com they will be able to find out, it plugs into the diagnostic port (take the glove box under the steering wheel out) and its on the left.
This will tell you which sensor is foorked and which needs replacing.
As for replacing, i cant tell you as i havent done it.......YET!
Also try jacking each corner up and making sure each one is connected.
You'll see the wire coming down by the suspension and it clips into the upright. I think it's a one screw job, I've got a knackered one I need to replace.
Yep just checked the book of lies (Haynes) - one bolt.
