becks7
Hi, has anybody experienced persistant noises coming from somewhere in the back of the car (internally)? I really cannot handle them, and cannot find the source. I also need an advice since my front seats squeek everytime somebody sits. It's the back rather that squeeks. What can I do? Do i have to replace the seats??? It's driving me mad...
Yeah I get noises coming from the back of the car, have you tried making sure the spare wheel is properly screwed into the wheel well as this causes noise when going over bumps, mine was loose and it was driving me crazy.
Well, I 'll try doing the spare wheel however since I have never used it I have my doubts that it is the problem. I strongly suspect it's from the back seat, or the boot door.
However, my biggest problem is that my two front seats squeak whenever somebody moves his back a bit. That's really something I cannot tollerate. It's getting me really angry[:@]
to stop the front seats from squeeking try pulling the covers off both sides of the seat and spraying some white grease on the mechanisms and then wind the seat back rest backwards and forward to work it into the gaps.
the noise from the rear would as the other guys said either be rear bottom half of backseats not clipped in propley or spare whee screw cap lose, maybe check the parcle shelf if none of theml could be woth getting some 1 to check over your suspention? :shrug:
I'll give all these a try soon. But how can I remove my front seat covers? I did not put any additional covring to the seats. Or you mean I must remove the original covers?
Thanks a lot!
Thanks a lot!
you need to remove the covers from sides of seats just unclips off try not to use wd40 because wd40 thinnens lubricants and drys out and will probably make it worse
