Tspoon999
14
Hello all.
Thank you very much for your input into this forum. I have spent many a hour reading on issues even when my car is fine.
However, I now an issue with my number plate lights. After my bulb blew, I replaced them withLEDs (mistake on my part). The lights worked for a while and then started to flicker so I bought standard osram bulbs but neither right nor left Number plate light work. There was no current going through to the number plate light holders but I have also checked all fuses.
My warning message on the MFD appears sometimes but not other times when no bulbs are present in the number plate lights but they disappear if I put a bulb in the holder even if it's just one even though the bulbs don't light up. I have also got error messages reset with the a VCDS.
Please can you guys suggest what I should? All my other lights work fine.
Thanks in advance
