ad_182_uk
242
Long Eaton, Notts
Went to get my map adjusted at monster today put on rollers and was runnin 20bhp less than when i haf jus a ko3 :/ guy said was running very lean and had a code about o2 sensor. He says replace this and shud b able to road test it at full beans as he cudnt do this wiv it running so lean.
This info sound about right?
Adam
It might be the cause but the fact its running lean can still throw up the fault code for the o2 sensor even if its not at fault.
That was the case with me when mine was running lean and fuel pump was on its last legs, o2 sensor codes havent been back since i put the lcr pump in
So if the o2 sensor is not at fault its probably the fuel pump? How can i check the o2 sensor without buying a new one :/ and fuel pumps are how much?
lean can also be attributed to maf under reading.. and the car fueling for the airflow it see's.. ie less than actually went in = lean
what are the 032 block saying, and what g/s does it read under a power run in 3rd or 4th?
Cant answer any of the above until i go back to the mappers. Before he would do
Anymore he said get a new o2 sensor so doin that.
Unless i can log that sort of stuff wiv the free vagcom?
Wednesday, 03 August 2011, 19:33:22.
Control Module Part Number: 6K0 906 032 AA
Component and/or Version: 1.8L 20VT EU3 0002
Software Coding: 10500
Work Shop Code: WSC 12856
2 Faults Found:
17511 - Oxygen (Lambda) Sensor Heating; B1 S1: Performance too Low
P1103 - 35-00 - -
16514 - Shareware Version. To Decode all DTCs
P0130 - 35-10 - Please Register/Activate - Intermittent
There you go Adam, these are tonights faults guys! but he did have a boost pipe pop off!
Replaced o2 sensor and no more boost pipes popping off, EML light stayed off for 3 to 4 days then back on again today.
Just seemed to come on totally at random car still runs the same seems to go fine but i still have no idea what its actually running or what the problem is?!?!
Stuck for ideas now, will hopefully get Arron to check code again tonight so if its same code as above i dont know what to do apart from change fuel pump as Berg suggested but i dont want to just change things if someone could find the problem rather than me just keep changing things...
Adam
