Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
Good to see you were testing on private roads![]()
I got the ELM327 bluetooth adapter working this evening
Just need to set up the car details to get it sorted. I used a BT stack called RoqyBT4 and the RoqyOBD4 addon, available through Cydia.
Can you keep these wifi dongles attached without experiencing battery drain? Ie. is it going to run my battery flat if left connected and the car is left for a long time?
There must be power to the port when engine is off. I have the wifi one and that still sends a signal and flashes when the engine is off....
I still leave mine connected tho
If your sitting in the car fine ... but when you get out and lock it ... 3 seconds later the power to the port should turn off the same as the interior lights.
