• Hi Guest There will be essential maintenance on the server on Monday 10th November from 5am meaning the website will be offline for a period of time. We will do everything to ensure the downtime is kept to a minimum.
I bought mine from someone on the forum so had holes already but even if it didn't, wouldn't have made a difference to the install process as we put extra holes in anyway
Sent from my SM-G965F using Tapatalk
Ok chap nice one
Reactions: FR3
Nice one chap. So does it already have pre-drilled holes on the splitter itself ?
It has four pre drilled holes which line up with four self tapping screws already in place on the car underside.
You remove those four, offer up the splitter and screw the self rappers back in.
There are another 18 pre drilled holes in the splitter which you need to use a 3mm drill to drill corresponding holes in the car underside. Then just screw in the self tapping screws.
You may wish to add some sillicant between the car and splitter as well.
Reactions: Naylor92
Cheers chap.
