not on mine but a mates, its running down from the head but its not the rocker cover gasket as just been done,
any ideas where its from??
I can put my finger in what feels liken half moon hole under this area. Should I not be able to do this? I have spent too many weekends fixing this damn car and don't feel confident with this tbh. How much would this job be at a garage?
I left everything connected and tested through the tip. I have been getting running rich errors and testing with this method found pipes under inlet mani to be at fault. I got the same fault code again today so I repeated the test and this time it was leaking from the gasket. I know that boost tests are usually carried out with breathers disconnected but I wouldn't have found the previous leaks otherwise. When I boost tested it with it connected I only ran 2psi through it as I knew running more would be risky. My car is quite high mileage and I have replaced various hoses as they go these last few weeks, only for the next weakest link to go asitwere.
The leak in the back corner has been there for a while and was on my todo list anyway.
