Any help?
1 - Gearbox casing
q Secure to the column-support → Fig.
q If changed, it will be necessary to adjust the input shaft, lay shafts and differential → Chapter
2 - Oil seal
q Always renew
3 - Oil bleed cap
q 30 Nm
q Always renew
4 - Dowel pegs
q Displace → Fig.
q Fitting → Fig.
5 - Oil level plug
q 30 Nm
q Always renew
6 - Retaining pin
q Fitted to the selector shaft guide to adjust the external elements of gearbox action → Chapter
q Displace → Fig.
q Fitting → Fig.
7 - Bearing bush
q For control rods
q Renew after removing
q Removing → Fig.
q Fitting → Fig.
8 - Needle roller bearing
q Removing → Fig.
q Fitting → Fig.
9 - Shim
q For input shaft
q Adjustment chart → Chapter
10 - Outer track of roller bearings
q For input shaft
q Dismantling and fitting → Chapter
q If changed, it will be necessary to adjust the input shaft → Chapter
11 - Outer track of roller bearings
q For 5th/6thand reverse lay shaft
q If changed, it will be necessary to adjust the input shaft of 5th/6th and reverse → Chapter
12 - Shim
13 - Outer track of roller bearings
q For lay shaft of 1stto 4thgears
q Dismantling and fitting → Fig.
q If changed, it will be necessary to adjust the input shaft of 1st/4th gear → Chapter
14 - Shim
15 - Outer track of roller bearings
q For differential
q Removing and fitting → Chapter
q If replaced, adjust differential → Chapter
16 - Shim
q For differential
17 - Oil seal
q Change → Chapter
