Hi
I have a 52 plate Leon Cupra, on coils, fmic, air feed etc..
I've recently cracked the sump leaked oil then drove to a nearby garage and got the sump replaced and since then the cars doing my compete nut in,
Right... Before i messed the sump it was booting to around 15psi, now its only boosting to approx 5-8 psi, not only that the oil light was flashing and beeping at me so today I got a new oil pressure switch fitted thinking it would be that but it still the same
So basically I have the oil light flashing and the cars not boosting correctly, I'm unsure what this is as there is no white stuff in oil cap and reading from other posts I thought it would be the oil pressure switch, obviously not as I've just changed it,
Also all my fluid levels are fine... Oil ok, brakes ok, coolant ok
The oil light only seems to come on at high revs then on off after that
Can anyone pleas help, thanks
