Oil Pressure switch
toonfiend
Hail to the Plug!!!!
Jun 27, 2008
159
Alright Folks, my new pressure gauge arrived today so will be fitting it at the weekend, cant find anything as to where the pressure switch is located (16V ABF). There are 3 sensors located on top of the oil filter housing I think it may be one of these but to know in advance will save a lot of fart arsing about.Also, will it be OK to splice directly into the wire from this to run the gauge? I dont fancy having to fit the sender unit its bloody massive! Cheers in advance TF:D
crezz
pedro motorsports
Jun 30, 2007
4,397
Woolacombe
im running the standard gauges which came with a new pressure sender unit..i had to replace the blue one with the new one which had two terminals on it...it needs two as the original one does the mfa
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
i bet you don't still per chance have the kit paperwork handy or a part number off that unit do ya ? ;)
crezz
pedro motorsports
Jun 30, 2007
4,397
Woolacombe
crezz
pedro motorsports
Jun 30, 2007
4,397
Woolacombe
yeah there is a company that does a replacement but you need to be in the trade to get it and apparently they werent alot cheaper
toonfiend
Jun 27, 2008
159
Cheers for that, so in a nutshell, excusing my ignorance!!... The oil pressure switch is the front right sensor with the blue collar on top of the filter housing?, the original wiring that is attached to it works the MFA, so when the new gauge is wired up the original wiring has to go on with it?. The sender unit I got has only got 1 terminal, will it be OK to splice the wires together? should get the same result.....shouldnt it???:confused: I`ll find out at the W/E and report back!, Cheers again TF.
