Hi, there's a few words of advise in this thread:6ft tall. Tried the seat high and low. Any advice?
Sent from my Pixel 7 using Tapatalk
Most cars are useless for tall folk, 6'4 here and if I get the seat at the right distance for my legs, the steering wheel can't come out enough for my arms. I have to compromise my legs in order to be at the right distance for my arms. Re the seat, I have it very low otherwise I can't rest my arms on the centre arm rest or door rest - the Formentor has the lowest arm rests I've ever known. They must have done their testing in Hobbiton.6ft tall. Tried the seat high and low. Any advice?
I'm 1.80 m (5' 11''), found my spot from day 1, easiest ever, best seats ever had, most supportive and most comfortable especially on long trips. Cannot see how one cannot find the right spot, they are outstanding seats. I set it almost all the way down and the back almost at 90 degrees with a little tilt backwards.6ft tall. Tried the seat high and low. Any advice?
Car seats are ’one size fits all’ and if two people are a similar height, it doesn’t necessarily mean they’ll both find the right spot from day one. We’re all ‘built’ differently, and there will probably be some owners who don’t find the seats outstanding and they struggle to get comfortable.I'm 1.80 m (5' 11''), found my spot from day 1, easiest ever, best seats ever had, most supportive and most comfortable especially on long trips. Cannot see how one cannot find the right spot, they are outstanding seats. I set it almost all the way down and the back almost at 90 degrees with a little tilt backwards.
Car manufacturers are not taking into account the whole lot of different size combinations that a man's body may be of. They are working on standard models, normally proportionate etc. If you are falling into one of those categories, being of not of an average height (shorter or taller) or you may have shorter or longer legs or arms or torso or whatever, it is your responsibility to thoroughly test/check/drive the car before buying it as most of us spend quite considerable time in our car and if the seating is not to our standards and liking then the use of the car is somewhat compromised.Car seats are ’one size fits all’ and if two people are a similar height, it doesn’t necessarily mean they’ll both find the right spot from day one. We’re all ‘built’ differently, and there will probably be some owners who don’t find the seats outstanding and they struggle to get comfortable.
With those two people of the same height - height may be the only common factor; one of those people may have a long body, short legs and long arms the other have long legs, a short body and short arms, and they could also differ significantly in terms of weight and build. There may also be other factors to consider such as medical issues (e.g. back-related problems) that would affect seat comfort, and finding the optimum driving position.
So trial and error and making multiple adjustments to seat fore and aft position, seat height, lumbar support, steering reach and rake and seatbelt upper mount on the B pillar will be necessary for some; others who find that perfect seating position on day-one maybe need to consider themselves fortunate.
