StephanCupra
50
South Wales
Is there any way to change this? It's an '07 LCR and whenever I use the keyfob, be it holding the button down or just pressing it, it only opens the driver door.
Where is this setting changeable if at all?
Regards
I think this is in the MFD settings if you scroll through the menu settings on there.
Where should I be looking? These are the only settings I can find (Sorry if im looking in the wrong place ive got a lot to learn!)
EDIT: I've just realised this is NOT the MFD. How do I access the MFD settings? (I've got the small MFD)
You do know that a double press of the unlock button unlocks all the doors?
:lol: I was just about to suggest this! Press the unlock button twice to open ALL doors. Press once just for drivers door.
Im sure I've tried this, though I may be wrong. Can anyone tell me how to access the MFD as there are probably some settings I'll be interested in.
I'll try the double unlock later, ha.
I'm not sure you'll have the options with the small display?! I may be wrong but I'm guessing you can only scroll through trip computer readings?
On the large MFD you have 3 menus, Trip, Convenience settings and Phone (or is it 4 to display radio as well... I can't remeber)
Just double click you're button lol.
From reading up on this forum it says you only get the MFD options if you have bluetooth built into your Leon. Then you have the bigger MFD screen if you do have bluetooth.
If you only have the small MFD then you won't be able to do it.
It can be done with VCDS though, whereabouts in South Wales are you?
*edit* Just realised youre in Barry town, from yesterdays thread. If you fancy a trip up to North Cardiff i can make the changes for you, along with any other tweaks you had in mind.
One press unlocks drivers door 2/3 then unlocks the rest.
Oooo that'd be awesome. And again excuse my lack of knowledge but what's VCDS?
I'll come see you, for sure! Where abouts are you?
Would have to be late one evening or a weekend im afraid, due to work. No prep needed, PM me and we'll sort something out
