options on front pads
gb
here and there
Feb 27, 2007
1,859
147
portglasgow
i have a 03 210 lcr and am needing new pads ,the car only get used about town and the odd blast at the weekend so im looking for options:D
andycupra
status subject to change
there is a guide in the info base for changing brembo pads.
its easy.
see here:
http://www.seatcupra.net/index.php?option=com_content&task=view&id=36&Itemid=6
as for how long is left on the pads after the light comes on, the only way is to take a look as this can vary. The wear sensor is on the near side only i think. The inside pad tend to wear faster than the outer pads, so if you want to check the remaining pad, id take the wheel off to check both sides properly.
Nev_LCR
Gone... but not forgoten
May 16, 2007
1,271
Ipswich, Suffolk
i can get a set for £100 posted from a tuner im mates with, may get them a bit cheeper if there are a few, (mods please dont delete i dont work for him just getting a good deal for members)
Jul 8, 2007
514
ive got ds2500's an way better than brembo when cold and as i recall not much more expensive or where they cheaper carnt remeber but dude get them there mint
DS2500's are cheaper then the Brembo originals and ALOT better. The DS2500's don't come with the wear sensor though so you have to join the 2 wires together that normally plug into the new pad sensor which is only on the nearside.
Lodgey180
WoOoOoOsShH
May 3, 2008
1,046
Middlesbrough
www.mootr.co.uk
same calipers just smaller discs..
same pads..
EDITED
my bad :(
the offset of the ibiza and leon are different so pads are apparently different
sorry richy
if i had and in stock i could of checked them out..
Lodgey180
WoOoOoOsShH
May 3, 2008
1,046
Middlesbrough
www.mootr.co.uk
Equally braking is as important as going, and front pads suffer somewhat on the 'R' cars. 10k miles out of a set of fronts seems about fair before the warning indicator lights up at around 4mm of pad depth remaining. The Brembo's cope with upto 300bhp so even modified cars have no problem stopping. OE pads are very pricey - £130'ish. You can retro fit Ibiza Cupra pads (no wear indicators), or others recommend EBC or Mintex offerings which deal better than the OE spec at high temperatures.
taken from google ...
