Would appreciate some advice on what is going on with my 2004 Tdi cupra.
The air con won't let me engage the compressor and as a result I can't get cold air.
I think I know why the compressor won't engage and that is because of the outside temp sensor.
The sensor reading on the dash is always somewhere between -15 and 0.
I have changed out the sensor for a new one, but that didn't change a thing. Still reading in the - range.
The sensor readings do fluctuate, so this along with the two sensors I have had, leads me to believe the actual sensor is working fine.
I am currently thinking that it may be a wiring issue somewhere.
I was hoping that someone would have a little more info on this problem before I resort to having a professional look at it
